Hi all,
I recently posted a question about my brakes, thinking that I might have a stickly caliper as the car has been juddering a little but have found out today that it can't be this and now I am stuck as to what the problem could be....
It seems to happen at lower speeds, around 2mph-15mph. Say you are coming up to a junction or traffic from 30mph slowing down, lets say you are now in 2nd gear going 15mph, when you come off the accelerator, with you foot on none of the pedals, just using the engine braking to slow you down before using the brake, the car is very juddery and looks like its kangarooing!
It only does this when not using the accelerator and whilst in gear between 1-2k revs. Looking at the rev counter, the revs are going up and down as it judders, they are just gently going down like you would expect them to.
So I thought it must be a siezed caliper/warped disk that is causing this but then I tried putting my foot on the clutch and its then as smooth as anything and glides along with no problem at all and will roll along, coasting perfectly, even at very low speeds, so I guess this puts the brakes out of the question.
So it only happens at low revs, only when not accelerating and completly stops when putting your foot on the clutch. So I am thinking a number of things but would like your views and opinions. And before anyone says anything, it is not my driving techinque!!!
Thanks everyone,
Russ
Thanks everyone,
Russ
