Just acquired a 2004 1.5 SE 5 door and wanna say hello
First area for me to address will be the lousy front door speakers - will my smart and punchy 17cm Kenwoods fit in the standard door fittings and does the door trim come off/on easily enough? How deep is the standard hole?
Next is the gearknob & gaiter - my gaiter is tatty and chafed, how straightforward or otherwise is access/removal/replacement. I've also got a ripspeed carbon fibre knob which might go on in place of the standard one if that's easy enough to remove - is it just on a thread that can be unscrewed or is it gonna be worse than that?
Last (for now) will be jettison the ghastly orange side repeaters - lengthy research has turned up just about no options - what have any of you used to replace the standard blemishes - I don't wanna get involved in risking dinging the wing getting it off or ending up with something stuck to the body I can't then get off when the bulb blows. Anybody using LED's in their sideflashers and which would you recommend/disregard as duff.
