any good performance ignition coils?
hey guys just wondering if their is any good performance ignition coils for the GA engine and what spark plugs are good for the GA, im thinking NGK Iridium plugs
GA doesn't use coils?
Do you mean leads?....if so stick with OE Nissan.
Plugs wise any more than a standard NGK on a stock engine is a waste of money.
i mean the single coil found in the distributor is their any higher performance replacements? their has to be something out there.
and for the plugs ill probably stick with my normal NGK's atm. thanks :)
yeah I read that ngk standard plugs (the copper ones) are actually better than the iridium ones but will require changing yearly.
Depending on mileage. There's no reason they shouldn't last a couple of years or more. Obviously worth checking spark gap at services but at around 7 quid a set delivered off eBay, its really not a problem
