its not a mileage based thing, its supposed to last the life of the car.
doesnt mean it will, running it low on oil will stretch the chain fast apparently
another likely option is just the cam/crankshaft sensors.
THE FIRST thing to do is to scan the codes and se what that light means - check engine light is VERY vague.
code scanners can be bought for as cheap as 2.50£
if it is what you assumed (cam/crank code) check the timing chain tensioner - if its protruded more than 10mm - change chain and both sensors (120£ parts) the expensive part is the labour though, thats why im spending so much time learning here!
R10tz0r thanks man for filming that! what a shame at the end though, coilpack and water leak..
did you have to strip everything back to the waterpump to fix the seal? u think the coilpack was ok before you started, might have dropped it? or was it shot all along?
it varies, tbh most mechanics near me arent bothered picking up jobs that are more than just replacing simple parts, service work etc but i was quoted 500£How much do car fixers charge to replace a timimg chain?
I'm at the scrap it or fix it dilemma. Got a few more months of MOT so no rush......yet
i had a n15 1.4 and never had a single issue with it... now the n16 on the other hand.. f'''##ing tons of issues electrical and mechanicalMy sr20de chain are very good condition. Engine mileage is 302000km and it was tight when we checked it.
I had 2 mechanics listen to the emgine, both said it was too quiet to be the timing chain, they suspect it to be the crank sensor, which is what the fault code says. Before invrsting time and money into fixing anything I put it through an MOT
