i know absolutely zero about car maintenance.
my 1.5 2002 almera failed to start this morning because the battery was flat. ( first time in the 3 years iv had it ,use daily )
my neighbour push started it for me and it was ok after that.
iv bought a RAC battery charger in case it happens again but dont fullyunderstand the instructions .
can someone tell me which option to turn the battery charger on to when charging is it
1. 6 volt trickle charge
2. 12 volt trickle charge
3. 12 volt fast charge
How long should i charge for the instructions does not specify a charge time.
the charger has a dial 0 to 8 AMPS / A
a green bulb
a red bulb (reverse connection ) ( besides it )
a white bulb (amber (6v/12v/ charging LED)
(green (12v fast charge complete LED )( besides it )
the dial also indicates 100 % to 0 % which im assuming tells me the powerin the battery.
thanks for any advice
a green bulb
