Big suspension or brake problem. Help please.
  • Thread starter Thread starter berzebut
B
berzebut
Hello again. I have a problem with heavy banging noise from the right front wheel when i hit any holes or any other bump. The "noise" it's the same with that noise who make a damaged drive shaft(for that who now), the frequenci of the noise is increasing or decreasing with the rotation of the weel.I was suspecting the drive shaft, I went to the dealer, we have made a drive test togather with a "official" mechanic, but he said that the noise is dosen't came from drive shaft. The car is new :december 2005, Almera 1,5L, not diesel.
After many insistences they changed the right side drive shaft in warranty(only the axe of drive shaft, wiyhout joint assembly or slide joint), but the noise still exists as before.
Now the noise makes it heard even when I releas the brake after a "heavy/brutal" brake . For that I suspect the brake sistem of the right side, more prececisly the cilinder body or the piston. In a pesimistic case could be a ABS.
I have to mention that I can't feel anything suspicious(vibrations) in the brake pedal or steearing wheel when the noise apear.
What do you say? How can I resolve this problem?
It's anyone who experienced that kind of issue?
I was. But the answer was " We dont know what is, wait till the noise sounds more louder, that way we manage to find the source of the prblem" To change the car with the new one is out of the question.
Remember, I am from Romania, here things goes in a "specific" not normal way. We are "the third world" of civilization.
The motto who drive's them is: you buy it, you drive it.
Thats bollox,does not matter where you are from,its under warranty,they HAVE to fix it,or else you demand a new car!
Today I was at official Nissan Service for the first "periodic chek/maintenance" at 15.000km, don't know the term in english. The price of this maintenance= 120 euro,very expensive, they have change oil, oil filter and air filter and the front brake pads.I have bought a month ago the brake pads from Italy with 75 euro for all 4 wheels, In Romania for the same brake pads pay 110 euro, don't know way, probably we are the reachest people of europe. I said to them to change the brake pads thinking that the noise will desapear, but no, is stil there.
About my "noise" from the front wright wheel, I was reprogamed to come again for wendsday 1-st of november to check the rotor and ABS sensor of the wright front wheel, because they are sure that the noise comes from the brake system.
Probably they are wright because the front wheel rotor of the ABS is pressed on the drive shaft and for that the bang nosie frequency is increasing or decreasing with the rotation of the wheel.
Anyhow, the god news is taht if you talk them loud and if you threat them with reclamations they are cooperative. So, "I'LL BE BACK" wendsday, hope with good news.
