Black plastic side trim removal??
  • Thread starter Thread starter RikaZ
R
RikaZ
Just wondered if the black plastic strip along the side of my p1 n15 is easily removable?? any bolt holes etc??? :confused:
Cheers RiKaZ
There shouldn't be any bolt holes as they are glued on with the worlds stickyest glue so they should just peel off, then use a hair dryer to heat up then rubb the glue left on the car (this bit is a pain in the arse and wil f**k up the skin on your thumbs) hope this helps
aye that helps cheers, just didnt fancy pullin it off then findin loadsa little bolt holes like me mate did on his fez. :D
i got glue removel from my mates dads garage which makes the glue rub off easy.
how much easier cos ive stil got some glue on mine which cant shift
bugger oh well it'll have to wait till I get i resparyed then cheers
it can be bought from shops i think he meant
best thing to do it get it really hot with hairdryer, it comes straight off. Took me about 30 mins to do both sides.
Then after, you use the tar and glue, job done
