hi, after fitting new battery my 06 1.5 petrol only starts with a bump, it seems to be turning over fine but first thing in the morn she has to be bumped after that she runs fine firing first turn of the key,,any ideas guys??
hi, had diagnostic done last week came up with camshaft sensor, fitted new one and cleared error code, eml has not came back on, just carried out another diagnostic with no fault codes found, starting ok just now, will check again tomorrow and get back,,thanks..
hi. just had car checked, now the dreaded timing chain needs renewed (according to mechanic)..says that's why she's not firing of the key, still no fault codes etc and no eml, does anyone know if these cars are variable valve timing or not as prices for kits are less than half, europarts going by reg says it's not but wont be first time....
