car veering
ive got standard suspension on the car instead of coilovers. the car drove great before with the coilovers/standard wheels combo, now with complete standard combo it veers left, right and anywhere constant with a steering wheel wobble, its basically all over the road!!
anyone with any ideas where to start?
My car does this too. Got the tracking done and it still does it. Took it back again, still does it.
Mine only goes left tho even on roads with no camber, or when i drive smack down the middle of the camber! :(
Apologies if this is too simple a solution, but have you tried checking your tyre pressures? Even slightly uneven pressures (especially on the front) can have it pulling in one direction.
You changed the suspension, and haven't had it tracked?
well i drove 85 mile down the A1 today and it wanted to veer wherever it wanted! im getting the tracking checked tomorrow so see what happens then
Ah right. Yeah i dunno about your issue, since its veering in all directions. Just sounds like something is loose. But alignment/tracking is def the first thing to try.
But veering one way could simply be tyre pressures.
edit: ignore this post :| for some reason i didn't see all the posts above before i sent it. must have not refreshed the page
