does any one know how i can connect my car alarm to the central locking i have the wires but dont know where they go the car alarm is a sniper 1 nissan almera n15 1999
That alarm system should fit to an aftermarket solonoid that's then connected to the rod system in the drivers door its a bit of a pain but it can be done
right easiest way to sort this is buy a twin wire solenoid off ebay attach that to the drivers door rods (under the doorcard theres a maze of these so use the top one running to the internal door handle) they arent too much make sure its just one, as you wont need any more and connect up as is in diagram C on your installation diagram (the solenoid is the bit at the top under diagram c) wire it like that there bobs your aunty and fanny's your uncle
pm me if you need anymore info as ive done these before also on mine
Hi, can you give me more details like what wire colors should I cut/attach it to and possibly some pic (being too hopeful here). I would appreciate your reply. Thanks!
