it should be very simple, just a few bolts, however be careful of pulling it off the car, as the side indicator is connected by wire it should just twist off or something. you may need to heat the sideskirt to loosen the glue though
Just took one off and the most difficult part is the bolts under the skirts, mine were seized so on snapped.
Take your time and watch the skirts, mine suffered minor injuries.
