Above the plate there are two very fragile clip in light units you need to use a thin blade or screwdriver to gently prise the units out. Too much pressure and the clips break and needing new units or some work to allow them to stay fitted & water tight. Build replacement is simple once unit is out.
edit: just seen yours is a saloon not sure if same clips are used or not send a pic to confirm.
All my pics are larger than 2mb will get a lower quality pic n confirm bt there's no space to get to the screws so I guess I have to work from the inside of the boot lid n try to get to the lights
