cold ai feed
Has anyone cut there inner wing to get a cold air feed pipe right up to there indicator vent? ( cant remeber the name for it )
cheers
Ste
can't see what you mean?
surely there's enough room between battery and inner wing to do that anyway.
also, my cold feed used to go to the fog light hole - there's even a hole already in inner wing to feed it down behind the bumper;)
edit: just thought and see what you mean now!! can't you go from the hole near the wheel arch to suteki vent?
can't remember the exact layout
cold air feed
Yeah seen that hole there aswell, I lost a fogy in a small crash wi sum old lady her tow bar went right through my fogy. Not giving Nissan £120 for one so got my self a cold air feed from Deemon tweeks to replace the hole I'm left with!!
Its 50mm in diameter and 900mm in length so should go straight up to my Induction kit!!
What induction kit are you using on that mate? Do you have you filter fitted into the wing or something lol?
I'm struggling finding a place with the cold air feed on mine too. I did have it on the hole on front bumper under the fog light but thats too low it has to be at least 500mm off the ground. I can't just leave the feed hanging through the hole in the wing cos when you put your foot down the pipe sucks onto the wing and loses air flow hahaha.
I don't want to lose a fog light so its either a suteki or maybe this way you're showing mate....i'm intrigued?!?!
Are you rite up next to the vent?
Thing is im losing power at abt 6 6.5 it just stops going! took the cold air feed of and its fine so im guessing its sucking its self in as its alittle squashed down the wing!
So i was thinking abt making the hole bigger so it wasnt squashed and hopefully getting full revs!
it goes through the hole in the inner wing not the hole next to the battery, it isnt squashed or anything, in fact my car seems to pull nicely, well it must do as my shakeys 1/4 times can vouch for that :cool::lol: engine is breathing very well :D
Im in the same hole as you sunny! Are you rite up to the suteki vent?
Main thing is am i safe to start chopping the inner wing? lol
