compression ratios for turboing
does anyone know the common/most prefured compression ratio with turboing the ga engine and can anyone tell me ho you go about doing it?
with the micra you could do it the getto way by useing two HG's or buying a 2mm sandwage plate form the ledgend matt humphris http://www.humphrisoxford.co.uk/motorsport.asp or work within the head opening up the combustion chambers.
cheers, martin
