yeah look wrong mate. here are the ones I bought a few weeks ago: Item number: 290132836777. fit perfectly, just need to make sure you put them in the right way round! If anything those bulbs look like the ones to do your heater controls with.
nis
well for a start it won't fit and don't use these bulbs they are just a LED and they blow quick
I had some white LED's for my side lights it was nice till I pulled up onto my drive on a night and found out the the right LED was flashing and the left LED blown.
if your getting LED's get the regulated ones with the 12-14.4 volt regulator on them less likely to blow and last a lot longer.
I had a similar problem they sent me 1 set with one bulb the right size and 4 the wrong size (like you received), I was lucky though e-mailed the guy & the (for some reason) sent me two sets of the right type, so I did my heater lights, & glove box light...
The guy I got them off from ebay were from germany and quite happy to send out more, hope you get it sorted as they look really good when fitted..
hi i was thinking of getting some blue bulbs for the dashboard to light up the speedometer etc just wondering how you fit them and is it easy to do i know it sounds thick but im a novice to these sort of things :lol:
i too am interested in putting new lights behind my dash...it should pretty easy. just unscrew the dial surround pull it out. take out the old bulbs and put in new ones. then reasemble. easy
