B
Bryan_H
Theres hesitation when you change gears and in 2nd theres a dead spot upto 6000rpm..any one know why this might be???it hardly has anything to do with a triple plated clutch?
Bryan_H said:Theres hesitation when you change gears and in 2nd theres a dead spot upto 6000rpm..any one know why this might be???it hardly has anything to do with a triple plated clutch?
Bryan_H said:The last owner did it,it has a lovly feel to it.well worth it and a lovly tight gearbox
Ya upto 6000rpm in 2nd gear its a dead spot as in nothing like 1st and 3rd,there very good gears.(as in acceleration etc).
@Dagnut,putting the cat back in wont make any difference would it??
DBull said:Triple plate clutch on a SR16VE...
That's a bit extreme isn't it?
Bryan_H said:it has 126.8 lbs of torque..
iamhappy46 said:Think he means the Exedy triple puck(triangular friction disc) clutch
DBull said:HKS filter is crap unless housed with a true cold air feed.
