dials
HIhi~~
Does anybody knw if the white dials found in the ltd edition "HURRICANE" fit the other grades of the Almera models??
Depends on which ones! If N16 (most likely are) then depends if theres differences between p1 and p2 and 1.5 and 1.8 sport and sport plus! they are the same size design etc, but slight differences mainly on speedo. N15 1.4 and 1.6 go to around 130 and gti goes a bit higher
As far as i believe, there is a difference in the wiring between the phase 1 and 2 N16 but they should just slot in if you can get the wiring sorted (waiting on Tech to get some info for me)
I'm also interested in this been after some white dials for a while now
i found white dials for the Nissan Almera N16.
As i thought the dials from the "Hurricane" were stickers where u can stick them on the oem of similar specs of the N16. But found out whole instrument dials need replacing.
Anyway
Here's the site where u can purcahse them from :-
http://www.carpartstuning.nl/Nissan.htm
