Oh yea, well you have to use brute force I think for the door handle surround. Try and lever it off with a screwdriver on the sides, not from the top and bottom because the plastic is thin there and it clips from the side anyway.
undo all the screws, and the handle one. with the lever surround still in place, lift the door card up and pull, the surround will fly off. not the best way but it works.
hidden screws... one under the door opener latch thing, and two under the big handle that has the electric window controls... you have to pop the top of that off and theres two in there
