door pop kits
lookin for some door pop kits,
since i got my back door handles flushed off, thought some door pop kits would be quite smart and handy instead of opening them from the inside.
does anyone know of any brand names, contacts for these things, heard of some not being powerfull to open doors etc.
would like some kind of "TVR" style pop button, as would like to mount them under the lip on the rear spoiler, if possible, one at either side.
any help, much appricated.
got them on my front doors mate
i used a central locking motor for both my doors (the botton is under each mirror)
aint had no trouble at all with them and they have been in for about 7 or 8 months.
not sure about putting in the back doors but, i wouldn't have thought they would have been much different. All you have to do find a place to mount it, then connect the motor to the rod that connects to your handle.
Quick explination:
when you life your handle up, your lifting a rod up which connect to the door latch. So insted of the handle lifting the rod, the motor does it when you press the button
in some cases, you have to adjust the latch that the door closes on to, which makes the door harder to close, but when you press the button it pops the door open further because of the force the door is under
i didn't have to on mine, they just pop open as normal
hope this helps
