door spaekers?
right a little while ago i saw two speaker brackets for the n15 door speakers! was wondering where the hell you can get them?
or is there antoher way to fit some good size speakers in there?
Make up some rings using mdf.
Take the oem speakers out and use them as a template for the mounting holes.
Then, you can do the same with your new speakers, before cutting it into rings.
Easy enough, but then you have the fun of running the wiring into the door itself...
