anyone know if these are available,or am i gonna have to mess about with the original wiring?cant really see a way to modify the original.
i drilled a new hole in each door to run my cables. had to take the doors off to bo it, but looks much neater. drill a 10mm hole just below the main harness, and use a grommet aswell, the hole is perfect with a grommet and cable is a snug fit.sparki said:Some of us have just placed whole new wiring in (just tuck it between door and door card, yes its badform but it works)
boghopper said:i drilled a new hole in each door to run my cables. had to take the doors off to bo it, but looks much neater. drill a 10mm hole just below the main harness, and use a grommet aswell, the hole is perfect with a grommet and cable is a snug fit.
