drivers window getting scratched!!!
i have 05 almera, drivers window and passenger window getting scratched on outside!! any solutions, :lol:
i have also fogged up headlights:mad:?????
you dont need to post twice matey....be patient my friend :)
On the window side of things, have you tried using glass polish? Auto glym do one, and so do many other manufacturers, have a search on google.
As for the headlights, im pretty sure there was a recall for that exact reason, check with nissan to see if yours was an affected model, if so they should change them for you....(certain conditions may apply)
Cheers, liam
could have grit in the rubber seal the window slides up and down on, take the outer seal off and clean it / run a pipe cleaner or something soft down and along the seal
my drivers side window is the very same and mines an 06,looks worse since i got the windows tinted.I checked with the dealer before I bought it on the headlight recall and mine had been done,it`s a fault with the bulb holder on them.
Re: Headlamps
I have just bought an 'O5 Nissan Almera ,and it failed NCT test due to headlights not being bright enough ! Nissan Ireland have told me that 05's were not on Recall .... What should i Do ?????
The original bulbs in mine were crap too.I put RING ICE WHITE bulbs into it and they are brilliant,they give out a real bright white light instead of the yellow light from the standard ones.I drive on back roads to work and the difference they make is unbelievable.You need the H7 type,between €15 - €20 depending on where you get them.
