ecu fuse?
have a decat and cherrybomb back box on my n15 and need to tune the ecu due to chugging because of back pressure.Heard that taking the fuse out for the ecu for ten minutes then put it back in and leave it idling for ten minutes will let the ecu adjust?anyone verify this?and which fuse does the ecu share with as its not labelled?sound!
Forget everything you have been told.
Back pressure is nothing, its all hearsay.
Unplugging the negative on the battery and pressing the brake pedal for 30 seconds will drain the system.
Then taking the car for a drive will let the ECU self learn to the setup of the car.
The chugging could be because of lots of reasons. Check the plugs and leads, and also clean the maf.
Tried out sams theory and i thought it had worked and she started chugging a small bit today again so will try out that rowdy,sound out!
