lookin at playin around with an ecu, a mate has an old sunny gti ecu laying around and was wondering if its the same as the mera?
wouldnt really of thought they would be that much diffrence like?Garnz said:hm i dont think it will work!
DBull said:Nope they won't work...well not without a bit of work.
The ECU pin out is the same shape but there are a number of pins that are in different positions.
The ECU's use different MAF's, therefore it runs pig rich with the Sunny GTi ECU and Almera GTi MAF.
One uses an internal coil and the other uses an external.
It can be done, but all you get is the higher rev limit of 7600 rpm...that's it!
Cheers
Dave
