FAO of all with coilovers
  • Thread starter Thread starter noddy
N
noddy
Just a quick question once the car has been slammed, how do you adjust the camber???????
Thanx
The front on the Almera can be altered with either crash bolts, slotted upper strut-hub holes, slotted top mount holes or camber plates...
I dunno if the Sunny N14 camber plates will fit the N15 ?????
The rear is a solid beam so can only be altered by bending it. As it's a beam though, the camber won't alter as you lower it...
