faut reading
  • Thread starter Thread starter spen
S
spen
is there any way to read a faut code other than with a machine at nissan that will cost me a fortune ???????????
hmmmmmmm you can get a OBDI or a OBDII Reader
you can plug it in and use a laptop to find the fault codes I think not 100% sure but try ebay first or other websites.
was kinda hoping there was a no cost version that i could have done but ill have a look thanks
You can get the gunson ones from halfords for about £30 i think,
uses the engine warning light to flash out a code which you refer to in the handbook.
There is a way of replictaing this with a piece of wire but i'm not sure how to do it. I'm sure it mentions it in the haynes manual???
a m8 has just asked me if i can do it that way but i dont have a clue as how you would do that its odb1 that the p1 gti uses incase anyone else needs this info
it has also just been surgested that it could be the transponder in my key how do i fix that then ? as its the only key i have
