1) Earthing Points - Where is the best place to earth the stereo and the amp?
2) ....... FFS, i do this all the time, i cant remember the questions i had to ask, i'll strip it out tomorrow and be like..."thats what i needed to ask"
we will stick with question 1 for now
cheers guys
The edge of the steel frame for the centre console has some easy access earth points - push the two clips from the bottom of the glovebox inward, drop the 'box and they're right there
No, there .... look up a bit .... in the middle of the dash .... that's them !
(10mm I think, or possibly 8mm)
Are you putting the amp in the boot ? If so, one of the bolts on the grey plates behind the seat will be fine, or those two really big bolts in the floor either side of the boot opening.
