Hi. I am wiring up an amp in my GTi. Where is the best place to feed the power cable from the battery through to the car interior ?
I have tried the rubber grommet on the passenger side of the engine compartment (about 30cm in from wing and about the same from top). There is a loom going through here but when I push the wire through it doesn't appear on the other side ? (should be behind the fan unit ?)
Any advice most welcome.
Thanks, Paul
Thanks, Paul
