Checked the fuses and they're okay. I cab hear the unit charging but its not doing anything. Its a seperate unit at the back of the fusebox from what I can make out. Wondering if its a pig to do...Thanks for the quick replies
have you had the radio out or messed with anything in that area recently? i know on p10s that if the hazard switch is disconnected the indicators wont work, might be worth giving that a quick check if you have done anything in that area recently
