All I know is that the GA heads have bad intake to exhaust valve size ratio, so I don't believe you can have huge gains there...
...an example would be that GA14 intake valve (28.9-29.1mm diameter) compared to GA16 (29.9-30.2mm diameter) hardly a 1mm oversize is imo not a big gain, if you already have the ga16 head you can use it but don't know of any head mods that are worth the while...the head is too small for any serious mods, but that would be for N/A...don't know about turbo but it should probably be the same.
Also thought about getting bigger intake valves there but there is hardly any place left to go bigger, and the intake cylinder runners are also too small and what I read porting is restricted cause coolant passages etc are close to the runners.
