Headlight issue
So i noticed a headlight bulb(passenger) was out but there was no dash light warning to tell me, replaced both bulbs as they came in a pack of 2, the other side went and now the dash main beam light comes on when dipped beam is on, is this because of a fuse is blown or a more serious problem.
Will take a look this evening as i had to solder in some new wires and connector to a previous mera but can't remember if the dash warning was on.
Thanks
Andy
Mine was like that, with the high beam indicator lamp lit and all. The earth wire was corroded on the left hand side H4 connector. Ordered a new ceramic connector with wires, soldered that in and problem was solved. :)
Yep had a look this evening and the H4 connector is melted!
Thanks for the reply!
