L
Ladybird12345
Just been told by the mot tester that my front driver side head lamp is loose and needs to be tightened is this a difficult job any help or ideas
It is probably the little plastic clip/tab on the bottom.
There is a small rectangular bit of plastic that sits in the metalwork under the light unit, the light unit clips into that and it has probably broken which is causing the issue.
Best way to check would be to remove the light unit. Im guessing by the model in your profile details the car has black headlights with the indicator built in? If so its simple to remove. Undo the 2 10mm bolts on the top, unplug the wiring and then pull the light towards the front of the car to release. If the clip is broken/missing the light will come out easily, if not then it'll need a bit of a tug. But then if it needs a tug I dont imagine that the problem lies underneath.
