Is there a light when you first turn the ignition to the 'ON' position? All available lights will self test then fro a few seconds. Either it's broken, in which case you'll see a space where a light should be, or it doesn't exist and you'll see no spaces.
I would suspect it may be a blown bulb in the dash as there should be a blue indicator light when full beams are on.
