heater control - only on full.!
help please.!
the heater only work when turned up to to full, not on any of the lower settings. mines a N15 1.4
can anyone advise on a fix please
cheers
You need a new heater card. around 30 quid from Nissan or cheaper 2nd hand from scrapyard/someone on here.
easy fix as said above either solder across break or solder a piece of wire linking the two strips together, brown plugged dohickey two screws bout size of a credit card
A 3x0.5" (ish) connector under dash just forward, up and left from clutch pedal. Unplug and remove unit with a couple of big phillips screws.
2 min job to find and remove. It's just a big connector with a credit-card sized circuit board with a simple single conductor track.
You'll see where it's blown. Clean blown area and solder (may even get away with conductive paint if you can get some).
Was a couple of years ago anyway. Think I paid 28 plus vat or something.
-phone-
Hi
I'm trying to solder the bit where i think the break is (as indicated by the continuity test).
I need some soldering advice.
When i touch the hot iron with the solder it vapourizes.
When i touch the circuit where the solder should go, it doesn't melt.
I can't seem to get the solder onto the card.
What am i doing wrong?
Thanks
No expert but this works for me.
Use the solder and iron tip together like a pen to 'draw' the connection.
If it's too hot cool the iron with a damp sponge.
Takes practice, I use the back of a bathroom tile for that.
Should the solder be touching the iron tip when i'm trying to do the repair?
Thanks
Be careful as i bought an expensive upgraded board and it blew as well, had other problems in the system that was causing the cards to blow
Hi
Thanks
Hi Just an update. Have soldered the card and it has been working fine.
Just wanted to say thanks to everyone for their help.
Thanks
