I've seen this problem on Citroens as well (mainly cos i work with citroens) i'm not saying this WILL be the problem, as i'm sure one of the site's Techs will correct me but it's either a resistor within the motor or it's the control switch on the dash - 9 times out of 10 it's the resistor that's fecked.
After getting the dash apart (which was fun when your winging it). All the connectors feel tight, I didn't take the controller panel out of the dash as getting the cable off for the air direction dial might be a sod to get back on. Everything feels tight. Any other ideas?
