Hello, Need help with tino abs fault
Hello everyone,
I have a Almera Tino with a abs fault which is driving me round the bend, The abs warning lamp comes on with the ignition and never go's out.
I have tested all the wiring to the sensors and this is the results.
front left 1.67 ohms
front right 1.64 ohms
rear right 1.16 ohms
rear left 1.17 ohms
when you turn the wheels all give a fluctuating signal.
I have even purchased a second hand abs pump from ebay which was guarenteed to be a good one ( i know it still might not be good) and the fault remained the same.
Any advice that anyone could give would be much appriciated.
Many thanks
Richard
You should really get it plugged into diagnostics somewhere. It might tell you the exact fault and save you wasting anymore money.
