hello newbie here!
hi just got a phase 2 n15 couple of questions i'd like your guys help on
1) induction kit and de cat worth doing??
2) best way to improve handling i.e. lower? etc
thanks in advance :)
neil
Hi neil, your best bet is to sign up for membership then the GTi tuning section is opened up, loads of stuff in there! Theres also 'members rides' which has a load of info that other people have already done so you can learn by their successes and failures :)
welcome mate! as corbs says £15 membership is the best mod you can do;)
get some pics of your car up, looks nice in avatar. is it already lowered? looks low
ok i'll look into the membership tomorrow and get it sorted!
i'll also take some photo's
i have no idea's what's been done to the car re lowering what do i need to measure to find out??
Welcome mate
Look for coloured springs standard are black or rusty ha ha if you look at it from the side does it look like a x4 really high? well a big gap between tyre and wheel arch.
Garnz
HI induction kit, not rearly unless its a viper inclosed style one, would personally recomend drilled air box and a performance filter (i have my old drilled air box yours for the price of postage)
decat the second cat/the one below the gear lever, yes defently recomend doing it, one of the first mods i did, only other way to remove the pri cat/the one in the down pipe is to go for a hot shot header from the states (ebay) would also recomend if your changing the manifold to go for a full stainless exhaust system.
handling, cant go far wrong with coil overs but there not exactly cheap, for a cheaper option go for a set of PI springs had them on my car for about 60000 miles and took a hel of a lot of abuse including the almera towing car trailers with vectras and the likes lol.
hope this is some help
cool thanks for that i'll pop some holes in mine thanks for the offer
think i'll leave the suspension alone! it's standard but seems to work well for now!
Welcome along dubati.
There are plenty of styling and performance upgrade ideas on the site, just join up and start searching, if you're handy with a socket set you will be in for hours and hours of fun.
Trug
