hello
i would like to hail everyone as i try to find out more about my car. its a 2005 bluebird sylphy g10
i would like to know if the service manual for the n16 will work for the g10. i am in the process of swapping a sr20det in my sylphy and want to know if the electrical diagram is the same for both cars. has anyone done this transplant?
if it has a qg18 engine in it now then they should be fairly similar I would have thought..... is it an auto or manual?
the car came with a qg15 engine and its manual. i cannot find the service manual for the g10 only the n16. from what i have read online the sedans are basically the samething. need some advice to wire the car. the qg15 cars came with manual transmission
the engine is already in the car.i want to start wiring it tomorrow. i basically got the diagrams for the n16 so hopefully everything goes well.
we have begun the wiring and the car has started but the problem is because the car uses a digital interface for the speed,tachometer and diagnostic interface,it cannot be wired directly to the engine since it is an older engine than the one that was taken from the car.I need help to build a curcuit or bypass to allow the interface with the gauge cluster.
