Help, door stuck shut?
hi guys need some help!
Went out to my car today and the door wouldnt open? my doors are fully delocked and dehandled. When i push the pop the latch releases but nothing happens? so i went in throught the boot, but i stil couldnt open it from there? how has it jammed shut? and how can i open it? When i pull the leaver to open, nothin!
anyone know how to get the door card off with the door being closed? or is it impossible as the screws are along the edge of the door? how can i access the latch mechinism?
any help would be greatly appreciated! thanx rim
dont know why its done it but i would assume its something siezed, someone else will probably know
cant see how you could get the door card off without breaking it, might have to just accept breaking the door card if nobody else can help
Both doors? I`m sure it`ll be possibe ( but difficult ) to get the door card off with the door shut.
im sure the screws for the front would be inaccessable when the door is shut and the ones at the back of the door are hidden aswell, all you could get to would be the one on the arm rest and behind the door handle
only the drivers side door, can open the passenger door, via the boot! i know the latch operates with rods, hopefully i can get access to them via the arm rest hole!
wouldnt that mean the interior handle has detached from the lock linkage aswell as the central locking going wrong?
yup window is stil fully functional. i had a listen today and when i pull the handle i can hear the latch moving so i dont think it has detached from the mechinism.
Dead lock? anyone care to elaborate? is there a way to reset this?
thanx rim
You can power up the Dead locking from the SECU and see if that will free the catch. Looks like you maybe paying a Nissan dealer to do it for you.
