Help on Suspension Please Guys
  • Thread starter Thread starter SickassSRI
S
SickassSRI
Guys need a suspension kit for my phase 1 SRI, jus wondered if any1 new where i cud buy a set, want the cheapest i can get cus me budgets low, used is fine jus need 2 get it sorted.
cheers guys
It you are just after it being lowered then a lot of car modification companies (needforspeed.co.uk, demon tweeks, etc) sell a few different brands of lowering springs to lower about 35mm. Not sure if there are any coil overs for the SRi or if they are GTi fit only?
basically me shocks are screwd, jus thought instead of jus replacin them with factory standards i'd upgrade them, wud jus replacin the shocks with brand new nissan 1's an usin lowerings springs b a gud idea or wud i be betta gettin a suspension kit??
Hiya mate, if ya get standard nissan shocks you wont be able to go lower than 40mm with the lowering springs (about £100), as they'll just destroy the shocks. i went 40mm with nissan shocks and was fine.
The alternative is to buy an uprated shocks/springs set, which cost about £200-250 and you can go to about 70mm i think?
After that you need to invest in some coilovers! (£500+)
Its up to you which you go for, and mostly which you can afford
but needforspeed.co.uk have a pretty good selection!
Hope that helps
