Hi all newbie with a blower relay issue/question
Hello I wonder if any one can help with an intermittent blower fault I've managed to get the PDF manual for the car and have gone through all the tests etc ie fuses intact ,blower resistor giving correct readings and so on ,the manual shows a blower relay situated on the back of the fuse block could this be the issue ...its a random fault as all I can turn the ignition on and it will be working again then all off a sudden a week later it stops I cant seem to be able to pull the relay out to test but would this be the starting point
Many Thanks Paul B
