High idle
Hi guys hope you can help me with this problem, I have almera 05 with 1.5 engine and manual.. It has 56k miles, I cleaned the throttle body last week, the idle got higher than before which around 1200 and it reaches over 1500 when I step on clutch preparing to stop or changing gear, check engine light is off... I changed the spark plugs and air filter and disconnected the battery over night but nothing happened, the idle still the same...mpg was 36 before I cleaned the throttle now it's 33....what do you think I should do?? Any advice?? I appreciate it
Sent from my GT-I8190N using Tapatalk
