Holes on the roof of N15
my pulsar srv was having roofbars and i take them off! so i put some type of plastic on them (dont know the word in english) but because of the hot sun they went broken! any ideas what to put to close that holes?
maybe its cheap doing that job in your country... here in cyprus is expensive! cause we must stick a 2nd metal part on the roof holes, then scrub the hole roof, then put on primer, paint and last lack! nearly for 100euro!
That doesn't sound that bad to be honest it's what you'd pay over here
if you do it you need to do it properly other wise it will look crap! just need to sand down the area filler sand prime sand prime sand paint sand paint sand laqure. easy pesy!
it aint as easy as that as for 1, youll need to put something under the hole for the filler to stick to, and if you spray just that area it will look shit
try rubber grommets instead of plastic ones
bit like plastic ones but more flexable and soft,
its just a different material,
