How much roughly will tracking cost?
Hi. My passenger side front tyre is bald on the outside but still good tread on the inside. Need to get the tracking done tomorrow.
Just wondered how much roughly I'm looking at paying.
Thanks.
£40-45 for laser tracking without camber adjustment (which isn't relevant unless you have coilovers).
£30 up my way for lazer.
Setting camber up seems to be a problem, not one garage here has a camber gauge!
I have some camber correction bolts for the Toledo, looks like i'm gunna have to buy one!
My Octavia allows some camber adjustment on the bolts that attach the lower ball joint onto the lower arm.
I'd assume yours would be similar?
An ATS near me measures camber.
I don't think it does on mine Rowdy, when we put new bottom arms on it I seem to remember the bottom ball joints were a snug fit.
I'll have to have a look next time i'm up at Dr Sims surgery.
Ok, got it sorted. The tracking was £12 but because my tyre was so bald I had to get a tyre, wheel balancing etc. ended up costing me £35.
Thanks for the info guys :)
Its had a 45mm drop on shortened shocks, needs camber like, the front has zero at best.
The rears aren't much better either, gonna get some shims for that.
20 to 30 quid for front wheel tracking,it will be the best 20 to 30 quid spent,trust me,when i car is tracked up right,it improves everything.
