Quite a rare item, people have made these vents themselves and some of them look very decent! worth trying if you're handy at the DIY, think theres a how to guide some where on the site.
Give the site a search and you should find some info on them!
there easy enough to make iv got mine to a point where i just need to make it look pretty. I basically marked out the area i cut drilles a shed load of small holes using a dremel then joined them up using a small millin tool (in the dremel again). you then need to seal it or you'll get condensation in the lamp, I just used some gasket sealent that I had lying around. after that is the make it look nice bit which im stil working on
