MOT states that a side idicator must be visible from directly behind and directly infront of the car. I take this to mean that if your front indicator wraps round to your wing then you can remove the side repeater. But remember, nissan put it there for a reason so be careful come mot time.
You have to be able to stand 3 feet out from the car, level with the rear bumper, and be able to see the front indicator flashing, hence the bulge on the JDM ones. Hope this helps!
I flushed mine and fitted subtle led bulbs into the mirrors, the effect of a smooth wing and bright indicator flashes from the mirror worked well, you could even see the orange flash surround the actual wing mirror glass from the rear in the dark
