bit of an odl thread to bring up, what a disaster it was though with the weather
the blue R was built by a guy called coxie, then he sold it to matty green, now matty has sold it on to JP, its probably the best example ive ever seen, pretty much everything has been done on it, last time it was rolling roaded it pulled 327WHP at all 4, 1.8 bar on a 3071r
the colour is poseidon blue
here is the full spec:-
ENGINE & TRANSMISSION:-
2 litre SR20DET
Re-bored to 87mm
87 mm JE pistons with JE rings
Crank lightened, balanced, knife edged and polished
Conrods balanced and polished
All new Nissan bearings
Lightened & balanced billet OS GIKEN flywheel
HKS 264 camshafts
JUN Adjustable vernier camshaft pulleys
Full head rebuild including triple cut valve seats, new valves,
Fully ported, polished and gas flowed
Cometic 1.2mm triple layer metal head gasket
ARP head stud kit
ARP conrod bolt set
GT3071R turbo
HKS adjustable actuator
HKS SSQV blow off valve
Custom modified engine breather set up
Samco water hose set
Samco blue vacumn tubing.
HKS EVC 4 boost controller
Full 3" exhaust including elbow
Custom made stainless steel tubular manifold Ceramic coated satin black
Stainless steel water header tank
Stainless steel power steering fluid tank
Stainless steel oil separator tank
Stainless steel oil catch breather can
Stainless steel intercooler pipe run
Stainless steel distributor cover
Stainless steel spark plug cover
Polished standard rocker cover
Nismo high pressure 1.3 bar radiator cap
Nismo adjustable fuel pressure regulator
Standard brand new damped nissan crank pulley
Forge motor sport billet aluminium pulley set
OS GIKEN single plate clutch kit
Braided Stainless steel clutch pipe
Quaife gear kit in fully re-built gearbox
short shift kit
Gear stabilisation bush kit
Nismo solid engine mount kit
Hks oil cap
Braided Stainless steel hose on all fittings
Braided Stainless steel oil feed, water feed and water return turbo hoses
Complete throttle body assembly rebuilt
Full Nissan engine gasket kit.
Walbro 255 lph fuel pump
Reverse mounted rad fans
HKS S45i iridium spark plugs
Mocal front mount oil cooler system with braided hose
3 inch front mounted intercooler core
Battery relocation kit
Blitz sus air filter
3 inch air inlet relocation pipe
All fixings used throughout car are either stainless steel or anodised blue aluminium
60 mm Apexi pillar mounted boost gauge
60 mm HKS pillar mounted oil temperature gauge
Custom made carbon fibre slam panel cover
Chassis;-
complete D2 coilover suspension kit with pillowball mounts
Custom made poly rear sub frame bushes
Whiteline anti lift kit
Whiteline sub frame align & lock kit
Fusion motor sport poly power steering rack bushes
Cusco rear upper strut brace
Cusco front lower strut brace modified to clear exhaust system
GAB front upper strut brace
All other bushes on car replaced with poly up rated versions
All sub frame, suspension and under chassis components freshly powder coated chrome
Up rated fully adjustable bump steer kit with protective rubber gaiters
GTi-R spares rear differential guard
Poly exhaust mounts throughout
Brakes;-
Wilwood 4 pot callipers with 310mm disc and rotor with EBC green stuff pads
Standard rear discs with Pagid pads
Fully re-furbished rear brake callipers
Stainless steel braided brake hoses front and rear
Brand new copper brake lines under car
AP racing silicone brake fluid DOT 5.1
Wheels:-
7 ½ “x 16 “Speedline comp 2 alloy wheels in white.
Goodyear eagle f1 tyres 205 x 45 x 16
Bodywork:-
Complete bare shell respray in metallic Poseidon blue including boot floor
Complete under side of shell stripped to bare metal and painted in blue
Complete under side of shell fully waxoyled after painting.
SPEC R chrome windscreen washer bottle mounted in boot
Custom made aluminium battery box mounted in boot
All trim colour coded except rear number plate surround
Clear side repeaters all round
Front bumper modified to accept front mount cooler core
Aluminium blanking plates either side of I/C core
Laguna splitter
New standard Nissan badges on tailgate
Sr20 inside logo on tailgate
Interior:-
Fully re-trimmed interior including door cards in black/blue leather
2 x fixed back black leather bucket seats
Standard interior carpet re dyed black
Alcantara covered dash board with custom pod housing vc boost controller unit
A-pillar moulded pod with 2 x 60mm gauges oil temp and boost
Lockwood white dial kit
Snap off steering wheel boss
Sparco flash2 steering wheel
B and M shortshift gear assembly
Pillar mounted shift light
