just wondering
Just want to no on a n16 Almera would a 1.5 petrol gearbox fit a 2.2 diesel if u can ans it would be greatly appreciated
Yeah, no chance. Why would you want to? The Diesel is 6 spd and stronger (136 DCi anyway), so going to the 5 spd would be a downgrade.
And could anybody tell me the best place I could pick up a sr20det engine and box
It depends which SR20DET.
If you're after a RWD engine then 200sx owners club would be a good start. They go for good money now though. The other option is a GTI-R engine which is 4WD and then you'd need Pulsar owners club or the like.
Is this related to the gearbox question?
No this is in relation to a different car sure would the pulsar gearbox not fit the both engines
Gtir 4wd gearbox will not fit the rwd engine. It will fit the gti engine but you'll need tue gtir flywheel and clutch The bell housings differ in the rwd and as Sam said what car is it going in?
....Phone....
You can't use the gtir flywheel on the fwd engine unless you sleeve it to use smaller bolts or swap to a gtir crank.
