key fob
hi there my keyfob is not working 2 unlock and lock the car does any1 no how 2 sink it bck 2 the car the batteries are all working in the fob cheers in advance
to
If its just lost its code then do this (while in or next to the car);
Hold down both buttons until the LED goes solid or for about 5 seconds
Release both buttons
Press red button and hold it down for a few seconds
Release and press it a few times.
This should re-sync it. If that doesn't work, it will either need to be done by the ignition method or you will need the master fob.
sorry to jump this thread but my gti came with 1 key and a master fob so i kept my old fob to use with this 1 (oval fob) i have try the key in the ignition but carnt even get hazards to flash any help plz plus never seen a master fob before how do u use them and what for?
The oval fob is a different system, it won't work.
The master us used to program other normal fobs to your car, I'd you can find any that look like the ones in the picture above.
-phone-
Will have a look around as only have the master one lol so need similar looking ones that say nats yes??? Cheers for the insight chris
Found 2 that are like the ones above but tried to get the hazards to flash but to no avail could some help me the f**k out as starting to do my head in
Provided you have the correct master follow this:
1, get in car with it unlocked
2, Put the car key in the ignition position (lights on) not started
3, Hold the red button on the master fob until the LED on it stops flashing
4, Press the red button on the master fob for 2 seconds
5, Hold both the buttons on the normal fob for about 10 seconds until the LED stops flashing
6, Press the red button on the normal keyfob for 2 seconds.
7, when finished, press the red button on the master fob.
Check everything works.
....Phone....
