lay down rear wiper
rite open your boot and take all the plastic off to get to your wiper motor, then take your actual wiper of (the arm) undo all the bolts and unplug all the electrics going to it, undo the screws holding the plate on it, then take the rotary arm out of the sprocket take the little metal washer out of the hole and put it into to the other one, then put the rotary arm back into the one you just put your washer into and then put it all back toghether and there you have it a lay down wiper and it also looks smart.
and by the way to get your boot trim of there is 2 screws and then just pull it of they are mostly clips holding it on.
Trug
